I upgraded from Windows 95 to WXPSP2 and had the same problem previously (no printing). I was instructed to run setup/setup.exe. and it started printing. However, my computer has frozen and, after changing one of the memories, my Canon multifunction MP C755 is again not printing at all, even when disconnected from the computer. Can anybody help me? JRibas ([email protected])
Not all OS's are created equal and one of the biggest hassles is having peripherals that worked perfectly fine in one environment not working in new one. And unless you can get another driver or patch for the new OS you are SOL
Sorry but that is the truth. And if your old OS was doing the job for you why did you upgrade? Never upgrade unless you absolutely have to because the pitfalls can be dastardly!!!!!!
SOURCE: New Canon MP480 How to scan copy into computer
Canon Link to your operations Manual :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=17160
SOURCE: Canon mp240
Go to the canon site and download the xp drivers, remove the driver
and software, clean your registry, and reinstall the software and driver.
http://www.usa.canon.com/home
Pretty good registry cleaner for free,,
http://www.ccleaner.com/download
SOURCE: how to scan documents with canon mp160
i press scan button then asking me to select publisher or photoshop, after select both but nothing happen
SOURCE: CANON MF5770 PRINTER/SCANNER/FAX PRINTS BLANK
Nesecito los driver para poner a funcionar el printer. Fueron borados por un virus.
SOURCE: Canon mp 980 won't even copy or scan if any
Sorry, but no. As far as I know that's how all of these all-in-ones work. If the printer doesn't work because the cartridges run dry, nothing else works either. They don't allow you to use the scanner as a standalone piece.
