Konica Minolta Magicolor 4690MF Multifunction Laser Printer Logo
A
Anonymous Posted on Aug 11, 2013
Default admin password 4690mf - Konica Minolta Magicolor 4690MF Multifunction Laser Printer
We had to replace the network card on Konica Minolta 4690MF and the "used" card has non-default password. Is there a way to reset the card so that we can login to PageScope?
A. Procedure
1. On the initial screen, press the Select key to call [PAPER SELECT] to the screen.
2. Press the following keys in this order.
Stop/Reset ? 0 ? 0 ? Stop/Reset ? 0 ? 1
now in SERVICE MODE.
Follow:
• Administrator number: 000000 to 999999
1. Enter the [SERVICE MODE].
2. Select [ADMIN. REGISTRATION] and press the Select key.
3. Check that the current ADMIN. No. is displayed and then press the [Back] key.
4. Enter the new ADMIN. No. from the 10-key pad and press the Select key.
DO NOT MESS AROUND WITH THIS MODE YOU WILL CAUSE MAJOR PROBLEMS
B. Exiting
• Press the Stop/Reset key.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Hmm
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Help me with my wep key please
Reset password of DGS3627 from console
Wanted to set password om my linksys
192.168.2.1
192.168.1.1
1helpful
New password wifi
How 2 put the password?
I looked on line to get a password, but it won't accept it. I have an I pad that works everywhere else.
2helpful
Forgot my password and cannot reset?
All D-Link Dir configuration done but I can't access internet,why is that?
192.168.2.1
192.168.1.1
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
