Question about Sport & Outdoor - Others
Winchester model 100 semi-auto 308 cal. how to disassemble?
Winchester model 100 semi-auto 308 cal. I need a disassembly procedure for this rifle. I don' have a manual with any procedures in it.
When I shoot, it won't group. Does the barrel have to be free-floating from the stock? Or how is this rifle bedded?
Any info or ideas on this rifle would be much appreciated.
  • 7 more comments
  • billy_cooper May 20, 2009
    mine is disassembled need to put it together
  • John Harris May 11, 2010
    Define not grouping, will it group 6 inches.Are all the Screws tight that connect the receiver to the stock.???The rifle should probably group 2-3 inches without a tune-up.That is adequate for most hunting purposes.I am easy to find at Fixya.I was a competition shooter in the Marines.
  • Anonymous Mar 12, 2014
    Disasembly and asembly of the Winchester 1910 rifle
    rifle has a new 2x8 scope but at 50 meters groups are 3-4 shots then 1-2 flyers from what should have been an excellent group
  • Anonymous Mar 21, 2014
    value of restored rifle
  • Anonymous Mar 26, 2014
    Need original replacement part, bolt handle. Replacement part from Numrich is too loose. Help.!!
  • Clarence Oleson
    Clarence Oleson May 24, 2014
    http://stevespages.com/pdf/winchester_10...
  • Clarence Oleson
  • Clarence Oleson
    Here's an owner's manual that shows field stripping' Note the part about removing the front sling swivel:http://stevespages.com/pdf/winchester_10... Here's an exploded view: http://www.stevespages.com/ipb-wincheste...
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Posted on May 20, 2009
How do i get the firing pin out of the assemble of a semim auto
Posted on Jul 23, 2009
    New Friend:
Kicks like a jack ! if u know what i mean. ur right its not cool for the barrel to ride on the wood ! and on this weapon the trigger is hard to squeeze! and loud ..sometimes im a littel gun shy!. it will shoot straight if u hold r steady. remember squeeze the trigger not pull. an a lot of practice!
Posted on Oct 31, 2010
You need to remove the bolt from the recevier and the firing pin is inside the bolt itself
Posted on Dec 18, 2009
    New Friend:
http://stevespages.com/pdf/winchester_100.pdf
http://www.stevespages.com/ipb-winchester-100.html
Here is a video:
Posted on May 24, 2014
SOURCE:
If I bought Winchester model 100 semi-auto how do I know the diameter .308,.243 or .308
There are 3 varients of the 100.
Model W8015 - .243
Model W8092 - .284
Model W7973 - .308
Sep 19, 2017 | The Optics
Hello anybody know
Yes, I do but please don't post disjointed posts like this one. You can bring your original post up be clicking Want Answer. If you rally want to repost, elaborate on what you said before.
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... date of manufacture and value: Click here to go to our gun values resource links.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
determining date of manufacture and value: Click here to go to our gun values ..... *TOO POST-64 MODEL 94 BEGAN WITH SERIAL NUMBER 2,700,000.
Winchester Model 94 Serial Numbers - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, winchester model 94 values, Winchester 1894, winchester model 94 prices, model 94 rifle, winchester lever action, 30-30 lever action.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden Memorial ... and find dates and serial numbers on The Winchester Model 94 30 30 ? ... I am thinking of trading the rifle for a 270 or 308 but want to verify its value. Winchester 94 w/no serial 18 posts 2 Oct 2007 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Blue Book of Gun Values - WINCHESTER FACTORY WINCHESTER ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
Add $50-$75 over individual prices for consecutively serial numbered rifle and ..... Model 94 rifle in .30-30 Win. cal. with octagon barrel, extensive C. Giovanelli scroll ... Other special issue receivers were used that bear this serial number as the ...
What Is The Year And Value Of My Winchester Model 94 Serial Number ...
www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester-model-94-s...
  1. Cached
  2. Similar
May 7, 2010 - I have a winchester model 94 30/30 lever action rifle . The serial number is 1208774. It is in mint condition. I was wondering what this gun is worth. Reply. avatar. Winchester Model 94 Pre 1964 Serial Number 1105022 4 Nov 2012 Where Is The Serial Number Located 31 May 2010 Winchester Model 94 8 May 2010 Winchester Model 94 30 Wcf Pre-64 6 May 2010 More results from www.gunvaluesboard.com
Value Of A Model 94 Winchester Rifle 30-30 Serial Number Is ... ' Gun ...
www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30-serial-numbe...
  1. Cached
  2. Similar
hey wiz sorry to interrupt and i know it is rude but i have a very poor money situation and need to sell this similar winchester model 94 30-30 the serial # is ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Jan 08, 2017 | Cell Phones
I got a win model 70 308 serial number 862911
You don't say, but I presume you want the date of manufacture?
http://oldguns.net/sn_php/winmods.htm
Other info for you.
  1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
  2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
  3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
  4. Related searches for win model 70 308 serials
  5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
  6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
  7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
  8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
  9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
  10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
  11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
  12. Pagination
May 24, 2016 | Optics
I got a win model 70 308 serial number 862911 whats this gun worth
Blue Book of Gun Values, plus what anyone is willing to pay. Condition is everything, especially condition of the bore. Taking it to a gun store is your best bet.
http://www.bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/...
I have a winchester ranger 270 cal. Rifle . Was wonde ring what model it is .... the serial number is G1871685
  • Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 ... 6.5×55mm, .264 Winchester Magnum, .270 Winchester, ... 70 Winchester rifles is the serial number ... the Winchester Model 70 rifle and Winchester Model ...
  • What is the value of Winchester ranger 270 caliber Serial? www.answers.com > ... > Firearms > Winchester Firearms Answer The Winchester 270 .22 was first introduced in 1963. It is not a collector item, or "rare". It is however a very good .22 rifle which should be enjoyed as ...
  • .270 Winchester - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/.270_Winchester Large rifle: Maximum pressure: 65,000 psi (450 MPa) Ballistic performance; Bullet weight/type Velocity Energy; ... The .270 Winchester (or 6.9x64mm) ...
  • winchester ranger .270 - Shooters Forum https://www.shootersforum.com/.../31131-winchester-ranger-270-a.html
    • 16 POSTS
    • FIRST POST: 2006-07-18
    2006-07-24 · Shooters Forum > Rifle and Rifle Cartridges > Rifles and Rifle Cartridges: winchester ranger .270 ... Winchester. Think push-feed M70 serial ... Ranger" mean? Caliber ...
  • What Is The Value Of A Winchester, Model 70, Cal. 270 ... www.gunvaluesboard.com/what-is-the-value-of-a-winchester-model-70... What is the value of a Winchester, Model 70, Cal. 270 ... of a Winchester, Model 70, Cal. 270 rifle. Serial number ... a Winchester model 70 270 cal the serial ...
  • 575 - Winchester Ranger .270 cal bolt-action rifle. Only ... www.proxibid.com > Firearms & Military Artifacts 575 - Winchester Ranger .270 cal bolt-action rifle. Only fired off one box of ammo.
  • Ranger T - Winchester LE winchesterle.com/Products/handgun-ammunition/ranger/t-series/Pages/... Ranger; T-Series; T-Series. When a ... Winchester T Series is ammunition that always performs at its best-even when things are at their worst. ... Rifle Ammunition ...
  • Winchester Ranger (M70?) .270 Win ' Gun Values Board www.gunvaluesboard.com/winchester-ranger-m70-.270-win-8295726.html I have a Winchester Ranger Serial # 5352836, 30-30 cal. Has a ... Tips for finding accurate ammunition for a .270 Win. chambered rifle. ... 1985 Winchester Ranger ...
  • Is a Winchester Ranger 270 cal a long action rifle? - Answers www.answers.com > Categories > Hobbies & Collectibles > Firearms Is a Winchester Ranger 270 cal a long ... What will excite ANSWERS.COM users for them to go ... The .270 Winchester is a great rifle for medium sized game such as ...
  • 270 Winchester Caliber Rifles for Sale - Online Gun Store ... www.ableammo.com > ... > Firearms > Rifles > Shop by Rifle Caliber We carry 270 WINCHESTER caliber rifles for sale in our online gun shop, including hunting rifles, tactical rifles, and more. We stock Browning BLR rifles, Remington ...
  • May 01, 2016 | Optics
    Winchester mod. 70 cal. 308win. bolt action serial#12236 in great condition what is it worth
    The rifle is from after 1952 but the serial number is from 1938
    As the 308 round only became available after 1952 but without the full number to age it value will be hard to tie down
    Mar 30, 2015 | Winchester Optics
    Loading data for leverevolution bullets in a Winchester 94 rifle?
    Here are some basic .30-30 specifications of interest to handloaders: bullet diameter .307-.308", maximum COL 2.455", maximum case length 2.039", MAP 38,000 cup.
    Medium burning rate rifle powders work best in the .30-30 with bullets in the popular 150-170 grain weight range. Examples of popular powders include IMR 3031, IMR 4895, H335, H4895, RL-15, and W748. For decades I have used IMR 3031 behind the 150 grain Speer or 150 grain Sierra Flat Point bullets and CCI or Winchester primers with excellent results.
    The Hodgdon Data Manual No. 26 shows that 31.0 grains of IMR 3031 powder will drive a 150 grain bullet to a MV of 2184 fps, and 33.0 grains of IMR 3031 will drive a 150 grain bullet to a MV of 2364 fps.
    The same source shows that 30.0 grains of H4895 powder will give a 170 grain bullet a MV of 1919 fps, and 32.0 grains of H4895 will give the 170 bullet a MV of 2212 fps.
    An unusual load with very low recoil that is excellent for plinking and small game or varmint hunting with a .30-30 rifle is a 100 grain bullet in front of 15.0 grains of SR 4759 powder for a MV of 1834 fps, or 18.0 grains of SR 4759 for a MV of 2034 fps. These loads give excellent accuracy in my Winchester Model 94.
    Mar 26, 2015 | Winchester Optics
    I just bought a winchester 308 model 100 rifle,
    hELLO THERE
    Please go to www.winchester.com and you will be able to enter your model number and there will be a viewable manual for this and there is also telephone numbers for tech support ok>
    Aug 05, 2009 | Sport & Outdoor - Others
    Sport & Outdoor - Others Logo
    10,094 people viewed this question
    Top Sport & Outdoor - Others Experts
    Marvin
    Marvin
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
