Take this for troubleshooting and solutions
http://www.repairclinic.com/RepairHelp/Dishwasher-Repair/9-129-576631-/Bosch-Dishwasher-SHU8805UC12SERIAL8104-Troubleshooting
SOURCE: Bosch Dishwasher classixx blows fuse when turned on
No don't hose it out. That will only make things worse. There are a good number of reasons why it may be blowing the breaker. You will need to meter out the different parts to check for a short. My guess from you description is that the softner unit has broken / leaked and gone into the main pump. You will need to replace both if thats the case.
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
SOURCE: My Bosch Dishwasher model #SHU43C06UC/17 in 5
Welcome to FixYa.
I would first run a diagnostic to see what error is presented and in turn will direct which way to focus the repair.
Try this and then let me know what you find aa a result...
This diagnostic posted below should guide you, let me know if it isn't clear or you don't understand something.
