Question about Canon PowerShot A550 Digital Camera
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
    Sergeant:
  • 246 Answers
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Posted on Apr 05, 2009
6ya staff
SOURCE:
Turn off light
what type of camera or model you are using ?
when the camera is set to automatic mode by default the flash flickers as it calibrates the amount of light needed to capture the picutre
try to set the camera on manual settings
or if you set the camera timer on once you click the shutter button the timer will then count down and a light will blink so turn of the timer
Mar 28, 2014 | Cannon Cameras
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
Nikon D60 - can not shoot pictures in low light
Quick solution: enable the "auto ISO" setting in the menus. This will automatically recognize low-light conditions, and adjust the ISO accordingly.
Dec 24, 2008 | Nikon D40x Digital Camera
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
Nov 14, 2007 | LG 52SX4D 52" HDTV
Camera won't take picture
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Nov 11, 2007 | Canon PowerShot A70 Digital Camera
Flash Indicator light
it´s a normal problem on the cameras, but to be fixed u will need to send it to a service centre, because it needs a board to be replaced.
Jan 15, 2007 | Olympus Camedia C-350 Digital Camera
OLYMPUS 410
It is something that seems to be a problem with the Stylus 410s. Olympus will not repair them unless they are under warrenty, I've tried. My best advice, and what I am in the midst of myself (I have 2 of these with the same problem) is to file with the BBB. Perhaps if enough complaints come through, they will begin to fix the stylus 410 defect as they should. Good luck. =)
Oct 13, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Canon PowerShot A550 Digital Camera Logo
501 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
