Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
