Remove front panel. Blower is in an enclosed metal assembly secured by sheet metal screws. Held on by lock nut, clamps or horseshoe ring. Secures onto motor shaft. Easy job.
According to Wikipedia "Lawn darts is a lawn game for two players or teams. A lawn dart set usually includes four large darts and two targets. The game play and objective are similar to both horseshoes and darts. The darts are similar to the ancient Roman plumbata. They are typically 12 inches (30 cm) long with a weighted metal or plastic tip on one end and three plastic fins on a rod at the other end. The darts are intended to be tossed underhand toward a horizontal ground target, where the weighted end hits first and sticks into the ground. The target is typically a plastic ring, and landing anywhere within the ring scores a point."
I have a. Vstar 1100 it's an 04 and has the pressure plate and to tighten the 6 bolts to the preferred pressure has the bolts completely touching the clutch pack outer most plate and doesn't leave enough room to even release the plates when you squeeze the clutch whats not right here???
8steel disc's and 8 felt disc's and goes as followed
metal fiber metal fiber metal fiber metal fiber metal fiber metal fiber metal fiber metal fiber. Metal-cap larger ring pressure-plate 6bolt ring bolts
The only way really is to use force and push with pliers on both ends of the horseshoe clip at the same time. You will need a good small pair of radio pliers to do the job.
check for blown fuses?you've most likely done that. open hood and look on the driverside fenderwell for a black main fuse and relay center or box, open the box and look under the lid for locations of relays and fuseslocation the fuse for electric widow and as you look at the fuse,you will see a horseshoe type metal ring inside the plastic 'window' if it's broken(the hORSESHOE} the fuse is bad and needs a new one.there is also a fuse panel located on the driverside of dash,open the door and you should see a removeable plastic cover on the drivers door at dash panel just to the left where the door closes. remove that cover to expose the fuse panel to inspect for blown fuses. thank you for choosing fixya.com
you need a compression tool to press down the metal plate... after you press it down a few millimeters, it will expose a snap ring in the steering shaft... you will need some kind of pick to remove the snap ring.... after you remove the metal lock plate, you will see screws recessed in the plastic... you have to turn the turn signals both directions to access all the screws
Lay the clip on the turntable with the legs in the groove. Using needle nosed pliers, point them straight down and reach down and squeeze the clip into place.
there is a groove on the top of rhe towel ring that the mount has an indentation that this groove sits in. The tiny screw pulls the groove into the mount in turn, holding the ring in place
