Honda 2001 1800 CB When I Receive it comes in broken up, but when I transmit its okay. @
SOURCE: GE 3-5814a cb
sounds like a voltage regulator to me. the speaker would not have anything to do with the transmit, the receive yes but, with no transmit or receive try the voltage regulator number on it will be ta7217 it will have roughly 10 legs on it and it will be attached to a heat sink or the chassis of the radio. also you might look at where the antenna wire connector screws on to the radio, on the inside of the radio on the back of the connector there should be a wire coming from the back of the plug and connecting to the circuit board , it could have came loose. Good luck.
SOURCE: Maycom EM-27 Transmit noise
you don't need a noise supressor, i belive you have to change the mic or check real good your mic, specialy the transmit botton
SOURCE: cobra 29ltd cb radio
A couple of suggestions:
1. verify that the RF Gain is maximum clockwise;
2. verify that the ANL or noise limiter is OFF;
3. pls add a ground strap from the body of the Cobra 29LTD to the chassis/GND of the vehicle or to your house GND connection;
4. Verify that your Wilson 5000 has a sufficient ground plane such as roof or metal objects.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: Have Cobra 29 LTD CB
Sounds like the PLL circuit....... no channel synthesizer will kill the transmit and receive...... bad crystal or IC could be at fault or if someone has attempted to add more channels could also be cause.
SOURCE: CB Radio will receive but not transmit
Sound Like The Modulation Amp May Be Dead..
Or a Componet in The Mod. Section....You Can Pick up The Repair Manual..@ www.samswebsite.com For about $20.00...Good Luck
