The cart body makes this process a little confining but it can be carried out without removing the pump from the motor.
Diagram courtesy of:
Refer to assembly 9 in the diagram. Remove the splash cup by working the push-on nut off the top of the cup.
Remove two Torx fasteners (13) and twist the nylon valve retainer gently while pulling up to remove it. Be aware of the small parts under the retainer.
The objective is to get the valve (12) out of the bore (A). Connect the hose and wand to the pump, make sure the wand valve is closed. Connect the water supply to the pump and turn on the water flow.
Place a shop towel over the valve bore and with the throttle in the off position, pull the start cord briskly several times to see if enough pressure builds to pop the valve out of the bore. If not, set the throttle to low and start the engine. Unless the valve bore is really corroded, this should pop the valve out.
If this process fails, you may have to unmount the pump and employ a more brutal approach that will likely require a new valve.
I have worked on my washer for the last 2-3 years to keep it going but I've opted to replace the pump this year. My replacement is an "AR RMV2G25D" (~$170) .
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
What you are describing is an unloader valve failure. The unloader valve (also called a spill valve or safety pressure relief valve) is sticking in what is known as bypass. Your pump is able to build pressure but when the trigger is squeezed, rather than directing the flow up to the nozzle it is looping the pressure back through the pump as it does when you release the trigger. Depending on the specific brand and model you will need to either replace the unloader or lubricate it if it is a Karcher with a spill valve. If it is a Karcher there is a known issue with the following models:
K2300G1 K2400HB K2400HH K2401HH K5800G K5800G
All of these have an issue where the spill valve sticks and will need to be lubricated with Vaseline or lithium grease. You can view a guide for this process at http://www.landanorthwest.com/dms. Select Maintenance/Karcher/Pressure Washers/All/Spill valve lubrication.
the part number is on page 9 of the drawing spill valve 45910400 hope this helps , we usually use some good quality silicone grease to lube the valve ,
unloader valve sticking in the pump head. remove unloader valve/ pressure reducing valve as per parts manual.
It will probably be caked up in white crystal type deposits if its an aluminium pump head. clean off the deposits and inspect the 'o' rings. if 'o' rings ok , apply silicon grease and refit.
It could also be a partially blocked lance jet not allowing enough water to come out of the lance if it is a flow sensitive unloader valve.
Hello: Here is a schematic. On page 2.1, part #1 is the unloader valve. You need to remove it and lube it with a very good waterproof grease. Also insure the O-rings are in good shape and the spring action is working.
The unloader valve usually is replaced. I dont know if you can get o-rings for it. But if you want to take it apart, there will be a crown or cap style nut just below the spring. Unscrew it completely and you will be able to remove the spool. There is just a series of o-rings on it.
could be allsorts. seals worn. ceramic pistons split, inlet manifold split( frost damage), unloader valve sticking, etc etc.
Put mains water pressure onto it and look for leaks, then run machine and see if it increases pressure, if not i would suspect unloader valve sticking.....
Not very familiar with the 1050 but i'm a service engineer for high press cleaning equipment...
