Garden Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mower won't start. wrong spark plug installed now sounds like to spark at all
panilling9
Level 2:
  • Expert 284 Answers
  • Posted on May 26, 2009
panilling9
Expert
Level 2:
Answers
284
Questions
0
Helped
214985
Points
961
J19LM champion would be your correct plug
2helpful
2answers
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
My huskee 21 173CC OHV powermore push mower starts then stops. What could be wrong? I changed the spark plug and the air filter.
Cindy, try running with gas cap off , if it runs OK then the caps vent hole is plugged, either try and clean vent hole or replace cap. It could also be a dirty carburetor which would need torn down and cleaned/rebuilt. Check the attached links,instruction and guides, Good luck
Why Your Mower Won Start Mower Reviews Consumer Reports
Lawn Mower That Starts then Stalls
Lawn Mower Starts Then Stalls
Engine starts and then shuts down
Jun 25, 2016 • Garden
The mower won't start
Rocky , start by replacing spark plug and remove old gas for new.
check links below for why mowers do not start.
Top 5 Mower Troubleshooting Tips Briggs Stratton
Lawn Mower Won Start
When Lawn Mowers Won Start
Mar 21, 2016 • Garden
1helpful
Will not start someone put wrong flue mix in
You will need to drain the fuel tank and lines, to get rid of the wrong fuel mix. Remove the spark plug clean and dry it. Rotate the engine several times with the plug out, to get rid of some of the wrong fuel mix. Install plug, fill fuel tank with the right fuel mix and start using normal procedures. If it does not want to start, remove the plug and put a teaspoon of straight gas in the cylinder. Install spark plug and try to start unit. You may have to remove the plug more than once and put gas in the cylinder.
Nov 13, 2015 • Garden
Won`t start
check for spark by pulling of the spark plug wire remove the spark plug and pull the engine over while holding the spark plug against the cylinder head
Sep 10, 2012 • Garden
1helpful
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
John deere lt 160 turns over but won't start
are you getting spark?is it getting fuel threw the carb
May 21, 2012 • Garden
Murray riding mower won't starter, new solenoid, new spark plug and trying start it from the start turn over but won't start and try from the solenoid still no go.
You need to pull the spark plug out, connect the spark plug wire and ground the plug to the motor and see if you have spark. If you have spark (bright blue) then it is a fuel problem. A yellow spark is and indicator of a coil issue.
Aug 25, 2011 • Garden
1helpful
2answers
Top Garden Experts
Jay Finke
Jay Finke
john h
