I have a simonz sph-2000 pressure washer. it doesnt have much more pressure coming from the nozzle than a regular water hose nozzle.
motor turns and regualtor turns off motor after a few seconds of not using.
after regulator turns motor off, the first second of spray has some pressure but none after. any help is appreciated
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
that must have been what it was. thanks for the help. i know my wife is happy because the honey do list can now continue.
