SOURCE: have a multip speed dremel 350
clean the slots that hold the brushes, sometimes they get cloged and the springs do not push the brushes all the way to the armeture.
SOURCE: Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
SOURCE: The variable speed switch on my dremel 395, can I get rep. parts
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
SOURCE: need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
SOURCE: Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
