I am having the same problem with my Bosch 11210VSR BullDog 5/8" Rotary Hammer, only after a few minutes of use, at which time the nose of it gets very hot. Could there be something broken or worn out?
You can't post conmments that contain an email address.
beneath the rubber grip there is a roll pin that needs to be punched through the housing to remove the regulator assembly. you can find a parts list a www.servicenet.dewalt.com it will shoe the location for the roll pin that retains the regulator assembly
Remove the left hand screw from the center of the chuck then lock a allen socket in the jaws and use an impact wrench to buzz it off right hand. If the jaws don't work then weld a nut to in and buzz it off with a regular socket.
This plug is usually just a shipping plug to keep trash out. Remove it and install a male quick connect. Put some teflon tape or paste on the threads before installing. Then your end of your air hose should have a female quick connect to plug up to the impact.
sounds like the packing is shot. you need to oil it 2 times a day if its a constant use tool, drain your compressor everyday if its below temps do it twice a day. before removing the packing try putting lots of oil 10 drops into the nailer it might just be **** caught in it but **** can ruin the packing.
Your throttle valve seal is bad or your trigger pin is stuck. Go to ereplacementparts.com and type in your model# this will give you a detail of the parts broken down.
Putting it in the freezer for a couple of hours may loosen the screw by contraction and or you will have to use an impact wrench unless it is completely stripped , then you will have to drill it out.
An air-powered impact wrench runs off of an air compressor with a tank – the air compressor should have at least a 10 gallon tank and be able to generate at least 3hp. Also, an impact wrench requires special sockets that are designed to withstand the high torque applied by the wrench.
