Sony VPL-EX5 Projector Logo
A
Anonymous Posted on Aug 11, 2013
Factory reset HOW TO RESET THE MACHINE
How do I reset the factory settings on an Iris washing machine? Wash 13 kilos
Pull the mains plug out, wait 15 minutes and plug it back in. Reset done..
1helpful
Bosch WAE24463 replaced drain pump and doesn't finish programs,F 18 shows .Factory reset?
If you have replaced the drain pump in your Bosch WAE24463 washing machine and it still doesn't finish programs and shows the error code F18, you can try a factory reset to see if it resolves the issue. Here's how you can perform a factory reset on your Bosch washing machine:
  1. Ensure that the washing machine is turned off and unplugged from the power source.
  2. Press and hold the "Start/Pause" button.
  3. While holding the "Start/Pause" button, turn the washing machine's program selector knob to the "Off" position.
  4. Continue holding the "Start/Pause" button for about 5 seconds.
  5. Release the "Start/Pause" button.
  6. Turn the program selector knob to the desired program and then press the "Start/Pause" button to start the reset process.
Please note that performing a factory reset will erase any custom settings or programs you have saved on your washing machine, so you may need to reconfigure them after the reset.
If the factory reset doesn't resolve the issue and the F18 error code persists, it's recommended to consult the user manual or contact Bosch customer support for further assistance. They will be able to provide specific troubleshooting steps based on the model and error code you are encountering.
Nespresso CitiZ Espresso Machine by De'Longhi. Turned on started process by pushing left green light but stopped process before coffee made. Now machine just makes a noise and no water coming through.
Question edited for full make model (what it is)', and change 'Citz' to CitiZ.
Try a full reset.
Reset to factory settings With machine being turned off, press and hold down the Lungo button for 5 seconds. LEDS will blink fast 3 times to confirm machine has been reset to factory settings.
How to Use your Nespresso Machine Citiz
https://www.google.com/search?q=nespresso+citiz+machine+stuck+pod+holder+reset
I forgot my password
You can perform a factory reset, but this will wipe out all user-level data on the machine.
Have you tried just pushing and holding the reset button on the underside of the machine?
Factory data reset: to erase all user's data on the Device as follows:
  • Click "Factory data reset" button to enter.
  • Click "reset device" button.
  • Click "Erase everything" button to start reset.
  • Wait until the device finishes the reset by itself.
The Device will turn off automatically. (It takes a few minutes).
1helpful
2answers
How do i reset my acer aspire to its factory settings
Hi and Welcome to Fixya!
To restore your machine back to the factory settings, just follow the simple step mentioned below. Be sure that you've backed up your personal files though before doing this because resetting your machine will wipre out any changes you have made on the machine.
For an Acer machine, just press Alt+F10 when you boot up the laptop. You will see Acer Recovery Management, select "restore system to factory default settings" then follow the on-screen instructions and you should be good to go.
Hope this helps!
Takasashi
1helpful
2answers
HOW DO I CHANGE THE PHONE NUMBER ON MY FAX MACHINE
go to menu setting there you can see factory default select and press .then machine will reset as factory default.off machine and on it again it will ask time ,date your fax address fax number everything give it.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
