Exercise & Fitness Logo
A
Anonymous Posted on Aug 10, 2013
Life fitness t3 works great except the incline won't incline and console reads incline off....
5 Related Answers
Anonymous
  • Posted on Jan 10, 2010
SOURCE: I have a life fitness T3 showing an error code 5.
running error
Anonymous
  • 83 Answers
  • Posted on Mar 24, 2010
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Anonymous
  • 83 Answers
  • Posted on May 07, 2010
SOURCE: I have a Life Fitness T3-0 which shows a
FET Stuck on Error / Err 5 - This error is probably caused by the driver transistor on the motor controller is detected to be shorted out. The fix is replacing the motor controller.
Anonymous
  • 83 Answers
SOURCE: FET Error
FET error is caused by a short in the driver transistor on the motor controller. Unfortunately, the fix for this is to replace the motor controller.
Anonymous
  • 83 Answers
SOURCE: Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
My treadmill LIFE FITNESS T3 blocked and the console display the following message : ERR 6 / ERR KEY BLOCKED. Turn ON /OFF. Does not fix the problem. What does it mean and how to proceed? Thank you.
How do I fix error 6 on my treadmill?
E6 Error: Controller malfunction. Resolution: Ensure that the cables connecting the console and the controller are secure. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.Sep 23, 2021
E6 Error Code: Control Board Malfunction - Spirit Fitness Support
https://www.google.com/search?q=LIFE+FITNESS+T3+ERROR
I have a life fitness T3 showing an error FOLDED. What does that mean?
The treadmill has a 'folding' feature for the incline setting. A safety switch must be reading this feature as not locked. Try this. Set the incline to 0% and the speed to zero. Step in front of the treadmill and using both hands carefully raise the whole front until the legs click and lock into place.
To lower the treadmill kneel behind the treadmill. Place your Right hand on the belt and lean your weight on it. At the back of the treadmill on the Left side panel is a lever. Pull this lever until the treadmill stops lowering.
How do you fix the error 7
The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjuste
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Which treadmill should I get?
Dear Sir, all depend how much do you want to spend
Guide from some friend, relative or some nutrional instructor.
God bless you
My treadmill life fitness 9100HR won't start
Have you checked the drive belt @ the motor, if it is OK then check the fuse, if it is ok then the brushes in the motor may be worn out
T3 - It slows down then speeds up, has mind of its own.
It sound like the Motor Control Board is failing call Life Fitness @ 1-800-351-3737 they will give you additional information and locate a servicer in your area
1helpful
2answers
I have a Life Fitness T3-0 which shows a "FET error".What does that mean?
4helpful
Fet error message
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
