SYMA Toys industrial New Syma S107 Radio Remote Control Helicopter Logo
Anonymous Posted on Aug 11, 2013
Hi, i bought a syma s107 yesterday and it worked fine! Today i crashed a little bit the helicopter and it doesen t work now. WHAT CAN I DO? HELP ME! then I turn on the syma s107 and the lights work good, the battery of the joystick are full charged, but when i want to move the wings, they don t work Help me! Thanks
  • Anonymous Aug 11, 2013
    help me pleasee
Rani wadia
Level 3:
Master:
  • Master 996 Answers
  • Posted on Jan 20, 2015
Rani wadia
Master
Level 3:
Master:
Answers
996
Questions
5
Helped
417040
Points
2461
Donot waste the time ,u should take a new one,,,crashed not repairable
john
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 03, 2013
john
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
389
Points
1helpful
Helicopter not stable
Hi, I had a toilet bowl effect after changing the blades on my s107g. After making sure the shaft was seated properly, I simply adjusted the tension on the screws holding the blades in position and after a bit of trial and error tightening and loosening: it's as good as new!
So i have the syma s107 and it as flying great and everything for a few days after a few crashes it still has great lift and what not. but now the whole helicopter like rotates while fying not in a yaw...
Make sure the drive shaft is seated properly. Gently, but firmly push it down towards the body both above and below bottom rotor. Also check shaft for any hair, thread or such thing that may be wrapped around it.
Let me know if you're still having issues, and we'll dig a little deeper.
PvT
1helpful
The tail rotor on my Syma s107 metal series helicopter won't spin. the battery is fully charged. the top rotor still spins. i don't know what to do
It seems tail motor is not working.
S107 knows to come with faulty tail motor.
If you open pilot cabin, you should see blue and red (or green and red) wire. See if they are welded on the motherboard.
If they are, then tail rotor is not working properly.
My S107 worked fine the fist 5 minute flight. On my second attempt nothing would happen. The green light on the controller just blinks. Occasionally when I turn them both on the chopper just takes off...
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
1helpful
1helpful
I have had my S107 for a week and it will not go back and forth everything else works okay
Back and forth movement is controlled by the prop on tail. Hold the helicopter in your hand move the right stick up and down to see if the little prop moves. If it works, then maybe the plastic prop itself... i.e. has a chip in it, or is bent/broken
17helpful
My Syma S107 will not lift off the ground. what can i do to sort this out?
Had the same problem - the rotors would spin but the helicopter would not take off. Finally tried tightening both screws on the piece just below the Balance bar. I tightened one of the screws about 1/8 turn, and now it works great.
Top SYMA Toys industrial Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a SYMA Toys industrial Toy Expert? Answer questions, earn points and help others
