Casio CTK810 61 Key Keyboard Logo
Anonymous Posted on Aug 10, 2013
Ctk 810in not able to read or play midi files
sarfraz khan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 18, 2015
sarfraz khan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
277
Points
Now I can play files from my SD Card, These are the steps I have done,
1 Changed my SD card, change it , its a must
2 Formatted card from laptop
3 Created a folder named "MUSICDAT"
4 converted MIDI files to .CM2 file using casio SMF converter in Windows XP in my case midi files worked fine no need to change to cm2
5 copy these files to the folder MUSICDAT
6 Inserted card in the keyboard
7 Selected the key CARD
8 Press button play.
Reuel Teoh
Level 2:
Champion:
  • Casio Expert 411 Answers
  • Posted on Jul 13, 2014
Reuel Teoh
Casio Expert
Level 2:
Champion:
Answers
411
Questions
Helped
112756
Points
490
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
5 Related Answers
Michial Gueffroy
  • 1140 Answers
  • Posted on Apr 23, 2009
SOURCE: Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Anonymous
  • 146 Answers
  • Posted on Aug 18, 2009
SOURCE: connect usbtocomputer
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
Fred Yearian
  • 5603 Answers
  • Posted on Sep 09, 2009
SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Michial Gueffroy
  • 1140 Answers
  • Posted on Nov 30, 2009
SOURCE: Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Anonymous
  • 192 Answers
  • Posted on Feb 10, 2010
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
1helpful
How to convert midi files into smf data files for casio 810in?
i found this for you
SMF Converter is software that converts commercially available Standard MIDI file (SMF) data to a format that is supported by CASIO electronic musical instruments, and then transfers the converted data to the instrument. After data is transferred, it can be used with the lesson function for lesson play. For details about using converted data, see the user documentation that comes with each instrument. http://music.casio.com/e/smf click the blue download button near bottom of page.---- not the four other links.
Jul 25, 2016 • Casio Music
Where can i get a ctk 481 driver
CTK 481 only has MIDI-IN and MIDI-OUT ports & no USB. So you need to buy a USB-MIDI interface (cable-like) preferably one that is class-compliant for you OS. Class-compliant device do not need drivers (PCs, MACs, IPAD).
Ctk 810in usb midi driver for windows 7 32 bit
Casio has this driver on their support page: https://support.casio.com/en/support/download.php?cid=008&pid=20 . Scroll down to the drivers section and click on the link for Digital Keyboards/Piano (excluding PL-40R) for 32-bit OS versions. This link is to the left. Currently the link for the 32-bit versions of Vista, Win7 and Windows 8 is https://support.casio.com/en/support/download.php?cid=008&pid=75 .
I hope this helps.
Apr 13, 2013 • Music
How to transfer recorded songs from ctk 810in to sd card
I want to practice through key board by singing along with with the help of SD card. How can record my favorite songs as karokee in SD cart to play in the instrument.
Oct 22, 2011 • Casio Music
I need to know from which sites can I download rhythms & tones which is compatable fpor my casio keyboard ctk 810IN
You can play back standard MIDI files from the SD card slot, or load them into memory via USB. However, it is not possible to add new tones or rhythms.
20helpful
2answers
How can i connect my ctk-720 to my mac & the garage band application.
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Nov 28, 2009 • Casio Music
1helpful
Connect usbtocomputer
"m-audio"uno
My casio 496 cannot connect to fruity loops
Unfortunately your model of Casio only has midi in and not midi out. You will be able to use it as an external sound module but not to input notes into Fruity Loops. In other words midi out of your computer to midi in of the Casio with the proper settings will play your Fruity Loops sequences through the Casio.
3helpful
Top Casio Music Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Casio Music Expert? Answer questions, earn points and help others
