Anonymous Posted on Aug 11, 2013
FACTORY RESET OF VPL EX-07 MULTIMEDIA PROJECTOR
5 Related Answers
stilyou
  • Posted on Feb 02, 2008
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Anonymous
  • 134 Answers
  • Posted on Feb 21, 2009
SOURCE: Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
Anonymous
  • 4234 Answers
  • Posted on Apr 09, 2009
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Anonymous
  • 10594 Answers
  • Posted on Jun 01, 2009
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Anonymous
  • 10594 Answers
  • Posted on Aug 25, 2010
SOURCE: need to reset the lamp hours on a sony vpl px40
Projector should be in Standby mode
Press RESET, <=, => and Enter keys to reset lamp timer.
That procedure is also mentioned in user manual page-39
Thanks.
How to reset to factory default settings on projector sony VPL-DX126
here's the user manual of the prjector:
https://docs.sony.com/release/VPL-DX126_DX146_DW126.pdf
i've readed it and i guess you should push the reset bottom in the remote.
Where is reset button in VPL EX 4
some models has another NOT. However you must read your owner manual or download from www. fitness.manualsonline.com or www. retrevo.com
Merry Christmas
1helpful
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Why dull lightoutput coming from the projector sony vpl ex 5
Its because of dust.Out bulb throw air to bulb and at projector through air blower or vacuum cleaner.You will get better result
Why is it in black and white and not color?
reset the settings to factory default and swap out the cable. if that doesn't work, you have a processor issue on the main board. it'll need to be replaced..
3helpful
My projector sony vpl cs6 projects yellow
reset the settings to factory default and change your cable. if that doesn't help, the polarizer filter on the blue lcd panel is fried due to excessive dust and heat. the optical engine will need to be replaced.
4helpful
Lamp time resetting
HI
1helpful
Sony
Turn on projector and Press following button on remote in following order for less then 5 seconds..
Above procedure is written in user manual page-49
If you need user manual of VPL-HS50, click Sony Support.
Top Sony Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
