I pull the inside latch but it wont open up
SOURCE: Hood Won't Open, and Lever Broke
Hi viper852004 , the only way you can do this is to remove the front grills and then you will be able to see the 2 sprung bonnet pegs, you will need to loosen the adjusting nut where it screws into the hood and unscrew it until it becomes unattatched from the hood, do this for both pegs and then you should be able to release the hood to fix the problem. the pegs will need to be reinstalled before driving the car as the hood will not close, hope this is of some help, regards mark.
SOURCE: hood latch won't release
This has happened to me several times, this will take two people, but all you need to do is have one person pull the hood release, while person number 2 pushes down on the hood, and then pulls up...that ought to do the trick
SOURCE: hood wont open on 1999 dodge durango
The cable has snapped. The easy bit is replacing it, the hard bit is getting the bonnet open to do so. Take it to a good local garage, or even to ford to open the hood, tell them you can't open the hood and say nothing. Let them open the hood for you, and close it slowly, just one click, so it it still latched, then change the cable.
SOURCE: my hood will not open, the cable release seems to
You can pop out the intake plastic grid and access the hood lock mechanism from there
SOURCE: gmc astro van hood latch not opening
Try smacking down on the hood with a open hand.You may want to have someone inside to pull the lever while you hit on the hood.If you do get it open spray everthing down with a good lubicant.Well good luck and hope this helped.
Testimonial: "It worked just fine .I also used some wd40.Thanks"
