IFB washing machine front load Showing ' Lo' what should we do?
In IFB Machine LO Error Code indicates Low Voltage Problem. We have the best quality Automatic Voltage Stabilizers. Gelco Automatic Voltage Stabilizer GA400 model will solve your problem. GA400 Voltage Stabilizer to up or down your incoming Voltage from GEB. It has a capacity of 12 amp and 15 to 20 Voltage up / down capacity.
We are sure this Gelco GA 400 model will solve your problem.
You can Call on: 9722658052 or 9427347880
Thank You
IFB washing machine top loader lo error what meaning
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Step by step pictures showing How to Dismantle Washing Machine for maintenance?
get the full model and s/n from machine and search on that also try LG...the search may take you there anyway
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
SOURCE: Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
SOURCE: My Whirlpool Duet Front Load Washing Machine is
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
