Some errors can just come up and you can just clear them and if everything works fine you don't need to worry about calling a tech. However if clearing it doesn't make the error message go away or you have problems emerge with the copier then you do have a problem.
E001 is an Overheating detection error.
E001-002 - The sub thermistor detects about 295 degrees celsius or higher. You would have got E001-000 for a temperature above 250 degrees.
Title : E001 Error Code That is Not Resetable Error : paper jam When the machine powers
up the E001 error code is displayed but cannot be reset. (Note: The reset
procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR) Workaround
: In this case, the Main Power Supply PCB Assembly was replaced. The machine
was powered up and the E001 code was able to be reset. The part number for the
Main Power Supply Assembly is FM2-0260-000. Remember, if the fixing unit
circuitry has an open or a short, the code may not reset. Be sure to confirm
the fixing unit wiring and try resetting the code before replacing the Main
Power Supply Assembly. Canon USA, Inc. Systems & Technical Support
Division1-800-528-2830
how many blinks do you see in the led indicator? if it is 5 blinks then the problem is the printhead. if it is 2 blinks, then problem is in the feeding mechanism. if the problem is the later, then you might have to bring the unit to an authorize service center to have it checked.
