5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out
chips failure as this tv has two big black ICs STK392-110 as convergence output,
replace them to fix tv problem.
Blinking light usually is a error code if blinks a certain number of blinks and the place to begin is to look for a bad fuse or bad puffed up caps inside on the power supply board--place to begin.........
Hit the front of the tv near the blinking light... give it a good rap or two. See if this helps. Helped mine. I had the same problem and the tech who came out to the house told me that it would work and it did! I could hardly believe it but it worked.
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
My TV surname off after 5-15 minutes of use. The red light in the front blinks once every 3 seconds continuously. If I hold the power button down on the tv, it will turn on and do the same thing.
