Samsung RS267LBBP 26.1 Cu. Ft. Side by Side Refrigerator with Twin Cooling System & CoolSelect Zone Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RS267LBBP fridge is not getting cold even though turned temp down
We recently had a bridal shower this weekend and were using the fridge allot; opening and closing it. We turned the temp down to 38 degrees and it stayed around 58, but we thought it was because we kept opening and closing the fridge. The party is long since over and fridge is now 60 degrees. Can't get anyone here to look at it till late in the week. HELP!
Anonymous
Level 2:
  • Expert 294 Answers
  • Posted on Apr 05, 2009
Anonymous
Expert
Level 2:
Answers
294
Questions
Helped
166096
Points
951
Hello , can you hear the compressor kick on ? and if so have you checked the door seal ?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
533
Points
GE TBX23 will not get cold. It has not been run in a year. Any ideas?
the obvious things to check is the temp gauge inside the fridge. is it turned up far enough? if so, then the gas inside the fridge is no longer useable. meaning you cant use the fridge anymore and a replacement is required.
even though the fridge has not been used in over a year, the gas inside acts just like battery does, if a battery does not get used for so long, the power still runs out and eventually the battery looses its charge, the gas in a firdge acts the very same way
Frige temp went up to 62 and won't come back down to 40. Try resetting and unplugging several times. Suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
1helpful
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
1helpful
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Hansgrohe shower
it's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Sep 02, 2008 • Home
1helpful
I have ? for model # ET1MHKXMQ00
Sounds like you need a new thermostat to me. They are kinda expensive, not too hard to replace though.
GE Fridge/Freezer Having to turn temp up just to keep it cold
That's a typical sign of the defrost cycle not working and ice is building up on the coils. That prevents proper air flow of cold air around the compartments. As ice builds up you get less air flow and things warm up soooo you turn up the cold which causes more ice to build up and even less air flow soooo you turn up the cold. See where I'm going with this? You'll have to check your defrost timer, defrost t-stat and even the heat element. Look in your owners manual or online for diagrams of where the parts are located on your older unit, then go from there.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
