Carb adjustment screw
SOURCE: i have a 1980 honda accrod 1.8 li....
The nob on the back is the idel set., the float adjustments are the 2 recessed areas on diverside on top of carb.. Be aware by turning to try to set float can cause problems. If you do turn be sure to count number of turns for each so you can reset to original settings if carb starts to flood or starve. What are you trying to acheive?
SOURCE: Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>There are Several Location for the Air Mixture Screws.
>>The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore).
>>If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required.
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Holding the Throttle Full Open, Start the Engine.
>>Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle.
>>Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle.
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: 1967 barracuda carb backfires do I adjust screws in or out?
I would check the float level first if you are going to adjust the carb., carters like to flood and if you check your spark plugs you can tell if your running rich. The other adjustment you will make with a simple vacuum gauge.You should probally check distributor points,and timing as well. More info would help, like is it back firing up the carb or out the exhaust or when accelerrating or decelerating.
SOURCE: wheres the idle adjustment screw on my carb.. i
There is a small knurled knob to the rear base at centre of carbies, this turns a worm screw, actuating a bar for all 4 carbs. The site below provides an exploded view and name of carby parts.
Here's a tip...if the knurled knob (designed to turn by hand) is too hard to turn, a multi facet (not hexagon facet) socket or ring spanner is far easier than pliers or grippers.
Cheers.
http://www.cmsnl.com/yamaha-fz600s-19861987_model9219/partslist/B-04.html
SOURCE: where are the carb adjustment screw
Here is some info, that may help.http://www.ehow.com/how_8049581_tune-echo-leaf-blower.html
