I want to repair a lavalier mic that lost sound. I opened it up and one of the two wires was off the mic. simple enough, I thought. So I soldered the wires... And it still doesn't work.
description: Two wires wrapped in black outer cable. One wire is like a copper sheath over the other wire which is covered in white. It (the white coated wire) might have some sort of polyester wrap on it or something as well.
You might want to check the other end as well. Take a ohm meter and check the wires to make sure their is a reading on both.The wire you speak of is called shielded cable and there should be no reading between the sheilding and the center conductor when they are seperated from the capsule. If there is a reading you have a short.To clarify, the outer sheild should read at or near zero when you check @ each end as should the center conductor ( the white ) wire.There should be no reading between the two (the sheild and the white) when they are unhooded @ each end. Also when the capsule is unhooded you should get a reading between the two terminals, if not the capsule is open and needs replacement.
