Nokia 6300 Cellular Phone Logo
Posted on Sep 03, 2007
Nokia 6300 Hi there, When I plug my phone in to charge - it shows as charging, when I unplug it - it is at the same spot and has not charged at all. I have tried it with different chargers . Please help.
A
Anonymous
Keep it on charge for whole night. Or else change the battery
Nokia 6300 fake charging it shows charging.
there is no fake charging, maybe your batterie is bad...try to change the batterie and try again...plz vote and rate this solution!
2answers
My nokia 6300 phone become heat during charging.and battary is also discharge rapidly
Hi
not heat but warm battery during charging is normal...but if discharges rapidly your battery may have reached the end of life..before buying a new battery pls make sure that your charger is ok...you can test it with another nokia with same charging plug..all the same on Nokia..
Hope this helps!
Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
6helpful
I am using Nokia 6300 model, when i am putting charger it showing as charging, but not charging, when i am replacing the same battery with other mobile then its charging, by that i came to know that there...
Hi! There some is a problem with the charger connection port, so you could always replace that. I had the same problem i got the phone charger port replaced, this saved me money on not getting any chargers.
Hope this helps Fazal Enterprise - www.fazalenterprise.co.uk
12helpful
4answers
Nokia 6300 charging not supported
When your phone shows charging not supported. First, you need to try a another battery on the phone, if it says the same thing, then try to use another charger, and if it shows the same thing, then you need to fix the charging port of the phone.
Before you do that, test, your battery and charger on another phone to see what happens, if they both work fine, then you need to fix the charging port of the phone.
Take care and good luck
1helpful
2answers
Charging problem with the nokia6300. stop charging and says charger not compatible
either your baterry or charger must is not working or their must be problem with the charger port........you need to go to noia care.......as there is no software problem......
1helpful
NOKIA 6300 HAVING CHARGING PROBLEM
the battery was discharged change the battery
Hi I have Nokia 6300, Now i have one problem,while charging
A lot of phones keep the background light on while charging to let you know when it has finished.
Moblie phone repair
I have bought a new 6300 phone housing on eBay. changed housing front and back,new buttons. changed motherboard,replaced everything carefully and correctly. the mobile turns on and shows everything as normal,,,, but shows Sim card not registered , wont charge, it plugs in and show data protection or something????? and shows no signal. I have worked at plenty of mobile phones replacing parts , this is over my head please help thank you.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
