Take the blade disc off the mower, you should have the nuts on the top of the disc for the blades, put the disc on the ground and remove the nuts on the blades.
Replace the blades with the new ones and fit the disc back under the mower
Take the battery out there is a number on it along with the maker of the battery which is likely Yuasa, then just google that info to find your battery.
should be a screw iether side above the blade turn clockwize to close the gap between the blades both sides should touch the cutting blade on the bottom you have to turn the centre blades by hand to make sure both sides are even but be careful not to catch fingers on the blades while turning
Cutting blade won't work
