SOURCE: My new LG Arena KM900 Calendar won't work
Normally caused by trying to put 24 hour times into a 12 hour clock or US date format into a European or vice versa
SOURCE: lg arena km900 turns on then turns off after 10 seconds
mines doing the exact same thing and its only 2 days old, did you get yours fixed? if so how, thanks cory. if you could email me a reply to [email protected] it would be much appreciated
SOURCE: My music player on LG KM900 Arena isnt working.
mine too.
Try transferring all the music files to the external memory, don't store them in handset.
It worked for me, so try it. N btw, don't use bluetooth.
SOURCE: My LG Arena KM900 could
Do you have the LG PC Suite software installed on your machine? You will need this software to access most of the functionalities in the phone.
Please download the latest LG PC Suite(Offline installer) from LG's support site at http://uk.lgairsync.com/cm.dif.DownloadStaticFile.tws?fileSpec=pc_suite
The file is around 115 MB in size, so be patient.
For more details, check out a similar support page at http://webtrickz.com/download-lg-pc-suite-iv-with-lg-air-sync/
Have a great time ahead.
Regards,
Brainiarc7.
SOURCE: Headset symbol stays on screen on LG Arena KM900
Hi!
The problem you described is generated by dust or dirt inside the headphone connector on your LG Arena.
The simple solution is to clean it by using a flow of air (from a compressor, compressed air spray or even vacuum cleaner ). Do NOT use your own exhaled air for this, because you will get a lot of moisture into the phone, that can damage it.
