Rci-2950 sypply might been connected wrong (one ELKO was exploded), radio works OK ,but usb is just a raspig , or wheezhing("rhrhrhr"). what is broken? , ismo
SOURCE: rci 2950 reception problem
Mannix, I have not checked skip conditions lately, but the last time I looked skip was not rolling at all so I'd be surprised to hear any australia,,,,,, Mechanic
SOURCE: no channel readout in front of radio ranger 2950
replace memory battery its a CR2032 battery Radio Shack and Walmart has them from $3.65 to $5 in price.
SOURCE: rci 2950
SOMETIMES THE SELECTOR SW GOES BAD ON THAT MODEL TRY TO SWITCH BACK AND FORTH
BETWEEN AM AND SSB PUSH IN AND QUICKLY
SWITCH BETWEEN THE 2 WITHOUT PUTTING IT INTO ETHER POSITION (I KNOW IT MAY SOUND SIMPLE)BUT IT IS WORTH A TRY IF YOU HAVE NOT TRIED IT YET........... GOOD LUCK
SOURCE: ranger rci-2950
Hopefully it's as easy as this carefully take the cover with the speaker in it off and look to make sure the speaker wire with the plug is plugged into the two prongs sticking up in the back right side corner it is a very tight fit though.Good luck Dan
SOURCE: rci 2950 no audio period rx or tx
Check TR38 I have seen caps in the circut
go bad more then once if you have a schematic you should be able to find it if one
is bad,a capasator meter would help but you
can check them with a ohm meter.
Good luck.
