SOURCE: My prestige induction cooktop PIC
E3 means that the stove is getting overvoltage.
Plug it through a voltage stabilizer
SOURCE: Prestige induction cooktop showing E3
Error Code: E3Reason: The voltage is higher for 3 secondsSolution: Check voltageSource: Induction Cooker Error Codes Explained
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
same here.. it shows P- all the time though it works perfectly...
That is the power boost setting it temporarily boosts by 60% more power http://www.prestigeappliances.com.au/ind...
