Nokia N95 Cellular Phone Logo
Posted on Apr 05, 2009
Nokia N95 8Gb fell,screen is white.
Hello! After my Nokia N95 8Gb fell,screen became blank white.Nothing on the screen.When I turn it on, I hear the sound,that it is loading,but nothing on the screen.I still able to receive the calls and I can make a calls,but again - nothing on the screen(screen is blank white) .Please,need help.Thank you.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
1861
Points
16
The screen cable may have become loose or dislodged. You can find out how to replace the screen and also to check the cable here - http://spyda.vox.comlibraryphoto6a00d09e7ac027be2b00d41442e37f685e.html.
You can pick screens up on ebay too.
MOBILE FELL INTO WATER
its flat of lcd is not working good and u may change ur lcd.but it may be from its IC, that time there is no way to solve. call ur cellphone when its lcd is blank if it is working change the lcd. cheers
Nokia n70m showing white blank screen...how to solve this problem
change a lcd first if problem not solw than make a hardware solution
Screen blanks out while am using,
ur screen is been misplaced . open it and plug it correctly thats it
22helpful
4answers
N70 Fell in water, Only White Screen is Shown
Don't put the battery / power on. Take the phone to the mechanic / nokia service center on urgent basis. They will remove the remnents of the water and salt over the circuit.
If the problem is still not solved, either the power supply or the motherbaord will require a replacement.
BLANK SCREEN
try to open it and check for loose connection from your lcd to your cellphone board.
Broken on the bottom
If you call nintendo or go to their website they will repair it or send you a new one if it is under warranty.
here is the nintendo link:
http://www.nintendo.com/consumer/systems/selectds.jsp
1helpful
2answers
Blank white screen, then off after 10 sec.
Try using a different battery. If that doesn't work, phone's IC must be damaged. Get the phone checked from a Nokia service centre.
Mar 22, 2007 • Nokia 3230
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
