We were watching tv when we heard a pop and the picture went out. The sound is fine - just no picture.
The TV is approx 2 yrs old and is a Vizio VP42 flat screen. Can it be saved?????
SOURCE: Vizio P50DHTV20A 50in.
Call for warranty service! This can be a power supply failure.
Jerry G.
SOURCE: Vizio GV47L screen went black and is now unresponsive
Change the main board if you have good picture and sound. If you don't have picture and sound, the inverter will also need to be change.
SOURCE: 50 inch vizio, no picture but theres sound!!
check y-sus board(top left with 2 white fuse)
check z-sus board(right small board with 2 white fuse)-view from back
blown fuse? replace that board. partstore.com or discount-merchant.com
SOURCE: we bought vizio 32 in flat screen tv 2 yrs ago and
On the power supply circuit board some capacitors will vent (top will pop open), dome, or bulge. They can be replaced but the board is two sided and easy to damage. Having the caps replaced at a repair shop is the best way to go. If diyers try it the board can be damaged and then it would have to be replaced. Repair may cost a couple hundred dollars, but a new board can cost that alone, not including installation.
SOURCE: Vizio model no.P50HDM, loud pop then no picture. Green pwr ind on
P50HDM, loud pop then no pic...
Exactly the same problem. . .a poof, then no picture. 2-year old Vizio VP42.
