Reset
Windows SBS administrator password seems to be a tough thing. But don't
need to be panic. There are two effective methods for you to reset Windows SBS
admin password. The first method may be a little easier than the second one.
Method one: Reset Windows SBS 2011 Password with Windows Password Genius
1. Download iSunshare Windows Password Genius, launch it and insert USB
or DVD/CD into your accessible computer.
2. Create a Windows SBS 2011(Windows Small Business Server) password
reset disk by USB or DVD/CD. Select right removable device and click "Begin
burning" button
3. Insert the USB or DVD/CD into your locked Windows SBS, set Windows
SBS boot from USB or DVD/CD.
4. Choose Windows SBS 2011 and user account, Click "Reset password",
then "Reboot" computer after successfully reset password to blank
Method two: Reset Windows SBS 2011 Password with Start Disk
1. Restart your Windows SBS 2011 with the installation CD or any USB/DVD
you can boot from and get access to the HDD drive.
2. Booted from SBS 2011 media, select Next
3. Select Repair your computer
4. Select your partitions and installed Windows version and click Next
5. Select command prompt
6. Change directory to the access the system 32 directory. Then your
original C:drive is changed to D: or E: depending on the number
of drive and partitions you have on that system.
7. Rename Utilman.exe to Utilman.old and copy cmd.exe
to Utilman.exe, exit and reboot
After the reboot select the Ease of access icon
8. You will get a command prompt and use net user admin user password to
change the password
At the user logon screen, press a combination of Windows KEY+U, then the
CMD.exe will appear. Type net user "Username""new password"
After you changed the password, exit the command prompt and login in with the
new password. Don't forget to change the Utilman.old back to Utilman.exe.
It could be that you will need to reboot with your media to change the Utilman
back.
Testimonial: "Thanks!"
Boot your computer to PCUnlocker Live CD (or USB drive). It allows you to <a rel='nofollow' href="http://www.top-password.com/blog/how-to-reset-windows-small-business-server-password-after-forgotten/">reset Windows SBS password</a> in no time.
SOURCE: forgot my password
restart your pc, then press F8 on your keyboard>then select SAFEMODE > windows will boot there you will select the ADMINISTRATOR ACCOUNT once you are inside windows you can change the username & password..
SOURCE: How to Unlock Windows Vista Password?
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
SOURCE: I forgot Windows XP Administrator Password.
This is an easy way to reset your forgotten administrator password:
Step 1: Download and install Windows Password Breaker.
Step 2: Burn a password reset CD/USB with the program.
Step 3: Remove the password with the created CD/USB.
You need to prepare a CD or USB.
