Konica Minolta magicolor 2430 DL Laser Printer Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a new installation cd for my konica minolta magicolor 2430
I misplaced my installation cd for my konica minolta magicolor 2430 laser printer and I can't get it to link up to my computer.
Anonymous
Level 2:
Sergeant:
  • Expert 210 Answers
  • Posted on Jul 09, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
210
Questions
Helped
114052
Points
556
Go to www.konicaminolta.com usa and download the print driver.
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Anonymous
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Renierf
  • 97 Answers
  • Posted on Aug 05, 2009
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
The fuser temperature is too high. There is probably some residue from the transparency left on the thermister or the thermister went faulty that causes a wrong reading. The only solution would be to have the printer serviced.
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: have a error flashing. Have disconected and
pull its drum cartridge out then fix it again.now restart the printer and check.
rtiql8nyj
DocuFlow Solutions, Inc.
  • 44 Answers
  • Posted on Jun 25, 2010
SOURCE: my konica minolta magicolor 4650DN laser printer
That's the Image Unit. It should also tell you what color. C, M, Y, K. Cyan, Magenta, Yellow, Black. Image units are seperate from Toner cartridges and don't need to be replaced as often. You will also hear people call it a Drum Unit. That's the same thing.
Print starts halfway down page - Konica Minolta magicolor 2430 DL Laser Printer
check your media, proper setting not metric versa inch. A4 is 8x11 1/2.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I bought a new HP Vista PC. I want to install a older laser ptr
Located on the Konica Minolta Website one can find in their Service & Support area software drivers for various models. Try there during your install.
Hi I have lost my printer software and have a new computer
This should provide you with the download for your driver:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=2430
Good luck.
Instruction for changing toner on Magicolor 2430
This owners manual for your device should explain how to replace this part:
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/MAGICOLOR%202430%20DL-_E
1helpful
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Konica Minolta 2430 DL Xtoner not installed
Check the toner contacts in the printer, you may find one either dirty , bent or broken.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
