1. Remove the toe grille. 2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside. 3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin. 4. Lift the refrigerator door off of the bottom hinge and set aside. 5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws. 6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge. 7. Remove two screws on bottom hinge with 3/8" socket wrench. 8. Install bottom hinge on opposite side with the two screws removed from Step 7. 9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench. 10. Reverse door handles. 11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam. 12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole. 13. Tighten center hinge pin with adjustable wrench. 14. Remove cabinet and hinge hold plugs and move to opposite side. 15. Lower freezer door onto center hinge pin (if you have a separate freezer door). 16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge. 17. Flip top grille and reinstall. 18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
Hi Mel, I looked for a manual for your fridge but couldnt find one. These jobs are pretty similar - regardless of brand however.
You should first deremine if your model does indeed support swapping the hardware to allow the door to swing the other direction. Look at the points of attachement for the handles and hinges on the door and the fridge body itself. There are typoically pre drilled holes for fasteners in these parts on the opposite side - but have plugs or covers over them to minimize their appearance. if you have these tell tale indicators present - you're good to go.
The process will require removal of all products stored on the doors of the fridge and freezer compartments, and placing in a thermal container or cooler.
The hinges consist of one at the top, one at the bottom and usually one in the center that engages both the bottom of the top door and the top of the bottom door.
At the top, you may need to remove a bezel or cover to gain access to the fastener head(s). Many times these are hex head screws, but could be any type really. Two, 3 or more fasteners may be used to hold the top inge to the fridge. Once the screws are loosened / removed the tops door will shift - so be ready for it (or have afriend support it while you remove the fasteners). The doors are surprisingly light - a thein meta outer jacket wrapped around a lightweight drame, lots of insulation and plastic is it really is. Lift the top door up and away from the center hinge pin. You may find one or more spacers or washers made of metal or more likely - nylon. Remove these and set aside as they will likely be needed to put back in place when the hardware is reversed.
The lower door is being help by the center and bottom hinges now. You should have access to fasteners holding the center hinge to the fridge. Support the bottom door as you loosened and remove the fasteners on the center hinge If you are unable to access the fasteners of the center hinge, try the fasteners on bottom hinge instead. If you get the center hinge loosened, you should be able to lift on the door slightly to roll it out from between the center and bottom hinge. otherwise, when the bottom hinge fasteners are removed, the door will drop and be free from the fridge. Look for similar spacers or washers on the bottom hinge pin that yuou found on the top of the center hinge pin and save them.
Remove any remaining hinges from the fridge.
Remove door handle hardware from both doors and remove plugs / covers from the opposite side of the doors. Secure the door handles to the otherside and insert the plugs and covers into the holes that had previously been used to fasten the handles.
Remove the covers / plugs from the fridge and insert into the opening that previously fastened the hinges to the fridge. Swap any covers / plugs on the doors for hinges if needed.
Reinstall the hinges and doors in reverse order of removal. If the bottom hinge was last to come off - it is first to go on. Reinstall the spacers on the pin. The bottom door is placed on the bottom hinge pin. Place the center hinge pin into the recess of the top door and secure the hinge to the fridge. Place the spacers over the top pin of the center hinge. Place the top door recess over the center hing pin. Align the top hinge with the recess on the top of the door and insret fasteners through top hinge into fridge. Hand tighten all fasteners. Operate doors and check for rubbing, binding, etc. Adjust number and location of spacers as needed to allow doors to swing without scraping or binding. Once satisifed, tighten all fasteners. Adjust feet of fridge as need to allow the doors to close by themselves if left open by accident. Restock fridge & freezer.
this is quite normal on a lot of fridges ! if it isnt closing again by its self you need to re-level the fridge and have it very slightly backwards . alternatively the fridge is not level side to side !. open the main door a third to halfway open and let it go, it should close under its own weight, if not adjust up on the hinged side leg or down on the opposite side , if the front legs are not not adjustable pull it out and adjust the back legs , a quick fix, is to chock up the front leg and all will be ok ,regards terry ps, clean the seals and the fridge where the seals make contact the seals probably do not need replacing unless the fridge is very very old. a lot of people replace seals when its not needed. regs terry
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
tilt unit backwards,and under hinge side you will see a bracket,undo bolts and transfer to opposite side leaving loose,slide door down ,then on top of door transfer plug to opposite side(if needed)slide door back up and refit bottom hinges/tighten bolts.
handle is just a matter of prising plastic cover of and unscrewing,then refitting to other side.
once you tip it backward its pretty obvious really.
The door can be adjusted with shims on the hinge post or by adjusting the cabinet by raising the front corner opposite the higher door. Keep in mind the doors are not designed to be perfectly even.If the difference is the depth of a quarter or less it is good. The seals making good contact all the way around is more important. Eric
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
