I am using Windows Vista Home Premium. My first attempt to transfer videos and pic to my pc from camcorder was successful however, I have not been able to transfer since! I have tried opening MM and importing from digital camera...it says no digital camera detected. I have turned off the camera and pc......reconnected cam to USB 2.0 turned on pc turned on cam in playback mode.... no luck. Device not listed under drives when accessing computer info? I have searched for drivers to download from internet no luck! I purchased the cam used so no disk. Do not understand how it worked the first time but not now?? Please help!
SOURCE: How to transfer videos on JVC Everio GZ-MG21U camcorder to DVD
YES!!! I GOT IT!!! Ok so the comp doesn't recognize the damn camera. I went around the problem!!! OOO so excited!!! Ok sooo simple, you'll slap yourself! Ok. First plug in your USB cord to the comp and you'll see the options play on pc, pc connection, etc. Select CREATE DVD! (You won't be able to see or select any of the files you are going to import, oh well.) You should see the regular screen pop up that says import, create, view pictures. Click IMPORT PICTURES. It will automatically import both pictures and video. For file name write something you can easily locate, ex: AAAAAAAAAAAAAA (you can change it later) Then open MOVIE MAKER. Click on IMPORT on the upper left hand corner and you'll see their demo video listed. Click on picture and video files on the bottom right hand corner and select ALL FILES. You should see what was downloaded!!! YAY!! I haven't burn a DVD yet but the files are there and the program should do it from there!
SOURCE: I need to download the driver
You should be able to find drivers here
http://www.jvc-victor.co.jp/english/download/camcorder/about_winxp.html
SOURCE: BRAND NEW JVC GZ-MG330AU Blank White Screen W/ Blue lines
If it is brand new and came with a warranty, return it. I hope the symptoms are continuous(not intermittent).
I have not been able to download any of my videos as well. I bought it brand new. I am using windows xp
Where can I find Vista drivers?
Also can not use I did before but now just says can not reconize device and comes up as a unknown device
