I have a general electric free standing range top with oven. i am trying to turn up the oven's pilot light. i pulled out the broiler drawer (or whatever that thing is) on the bottom, so i can see the pilot eaily. yet i cant seem to find any adjusting piece. PLEASE HELP.
Thanks
James
since it is piotless how did you light burner pilots? The oven is piotless and does not have a free standing pilot. here is a link to manual copy and paste page 18 deals with oven.
For a detailed Range/Stove/Oven illustration, click below.
Gas Free Standing Electric Free Standing Gas Cooktop Electric Cooktop Gas Walloven Electric Walloven
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
Is there a gas pilot light that stays lit all the time or does it have an electric pilot light that glows red to start the oven.Either way if it's a gas pilot the thermocouple is bad, if electric the igniter is bad.
To Clean:
IMPORTANT: Before cleaning, make sure all controls are off and
the oven and cooktop are cool. Do not use oven cleaners, bleach
or rust removers.
1. Remove the burner cap from the burner base and clean
according to “General Cleaning” section.
2. Clean the gas tube opening with a damp cloth.
3. Clean clogged burner ports with a straight pin as shown. Do
not enlarge or distort the port. Do not use a wooden
toothpick. If the burner needs to be adjusted, contact a
trained repair specialist.
4. Replace the burner cap, making sure the alignment pins are
properly aligned with the burner cap.
5. Turn on the burner. If the burner does not light, check cap aligment.
The solution to this problem depends on whether the oven is electric or gas.
Electric oven. If your electric oven's bake or broil element isn't working properly, either it isn't receiving electric power or the element or the oven control may need to be replaced. In many cases, the wiring to the elements can be burnt or broken.
1) Be sure the controls are set on the proper setting.
2) Be sure the stove is plugged in and/or check the circuit breaker or fuse that serves that circuit.
3) Call an appliance repairperson or replace the element yourself as follows.
4) Unplug the oven and let any hot parts cool.
5) Unscrew the mounting screws that secure the element bracket to the oven and pull out the element far enough to access its terminals. Note which wires are attached to each of the terminals, then disconnect the wires (pull off the wire clips or unscrew the wires).
6) Take the element to a parts dealer, along with your oven's model and serial number, and buy a replacement (preferably the manufacturer's suggested replacement part).
7) Reverse the process to reinstall.
Gas oven. When a gas oven doesn't get hot, it generally means that it isn't receiving gas, the gas valve isn't distributing gas to the oven burner, or the ignition system -- either an electronic ignition or pilot light -- isn't working properly. A common problem with ovens that have a pilot light is that the pilot light has gone out.
NOTE: Gas ranges younger than 10 years old have a sophisticated fault code system that governs their ignition. Always call an approved warranty service provider to handle problems with these ranges.
Here's how to troubleshoot your range:
3) Check the gas valve to be sure the gas supply is turned on (also make sure the house's main gas valve is turned on).
4) On a stove with a pilot light, make sure the pilot light is burning. If it isn't, re-light as discussed HERE, or in your owner's manual.
5) Adjust the pilot flame (older stoves only).
6) Turn off the gas and unplug the stove (or turn off its circuit at the electrical panel).
7) Clean out the oven burner ports, using a stiff wire.
8) Plug in the stove (or turn on its circuit) and turn the gas back on. Re-light the pilot (if it has one).
9) If the oven still doesn't work, call an appliance repairperson.
