Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
There is no replaceable CMOS battery on this model.
It is probably a rechargeable battery on the motherboard.
See Manual which only mentions the main battery pack.
Is this an ASUS charger and battery? Some ASUS laptops will not charge after a certain charge is reached, but it's usually in the 95-100% range to prevent overcharging.
If you bought an aftermarket charger, it may very well not have the amperage to charge while running the laptop.
Is it a replacement battery? Are the specs the EXACT match, DC volts and Amps? Some inexpensive batteries do not work well with your laptop, it's a Connector/ pin thing, they don't communicate with the laptop. Try pulling the plug and drain the battery and recharge. Cycle it a 4 times, drain/ recharge. Does your BIOS setup have a Battery Learning section?
Your laptop is 2 years old? Your battery is dead already? There are many online battery sellers, just do a Google search. BE ADVISED, Beware of cheap batteries, Look at the ASUS website for a replacement and a price. Use the model of your laptop and crossreference the battery Model numbers and power specs. Remember, the batteries that are cheap are cheap for a reason. That said you can usually find a battery for less than a laptop maker, ASUS, will charge. You can start looking here: http://www.amazon.com/Asus-U50F-RBBAG05-Laptop-Battery-Replacement/dp/B004FOR4Y2 .
Asus G72gx Series Laptop Part Replacement:<br> <a href="http://www.laptopparteshop.com/asus-g72-g72gx-keyboard-replacement.html">Asus G72gx Series keyboard replacement</a><br /> <a href="http://www.laptopparteshop.com/asus-g73-white-keyboard-replacement.html">Asus G72gx Series white keyboard replacement</a><br /> <a href="http://www.laptopparteshop.com/asus-a52-k52-g51-g60-g72-g73-series-backlit-keyboard.html">Asus G72gx Series backlit keyboard replacement</a><br /> <a href="http://www.laptopparteshop.com/asus-g72gx-battery-replacement.html">Asus G72gx Series battery replacement</a><br /> <a href="http://www.laptopparteshop.com/asus-g72gx-cpu-fan-replacement.html">Asus G72gx Series cpu cooling fan replacement</a><br /> <a href="http://www.laptopparteshop.com/asus-g72gx-lcd-hinge-replacement.html">Asus G72gx Series laptop hinges replacement</a> <a href="http://www.laptopparteshop.com/asus-g72gx-lcd-cable-replacement.html">Asus G72gx Series video cable replacement</a>
I'd ask your professors which one they recommend and if they don't have a recommendation ask them what they use or better yet what they would like to use if they could afford it!
good colleges should recommend a compatible laptop that will easily sync with their school system!
