SOURCE: lights flashing
the flashing lights is an error message, the flasshing may be a sequence of flashes, which designates an error code. speek to the tech support from the manufactur to decode the message & see if there is an easy solution
SOURCE: canon pixma mp810 won't power on. Power light
Canon Pixma MP810 will not power on at all. Is there a fuse? No info in manual. Unit is about 3 years old.
SOURCE: my printer canon pixma MP140 All-in-One is not
Hi there you try.
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I have a Canon PIXMA MP530 printer and showing an
disconnect it from power for 10 minutes and also check for jammed paper. That should do the trick
Rob
Ps. Thanks for ratings.
