Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dhjjd
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water
and/or solution sprays through the handheld tools, but not through the
main machine.
As others have suggested, I removed the water
reservoir, which exposes the 2 main water sprays mounted above the
rollers. Using, pliers, I carefully slid the clips back. Gently but
firmly removed the two red nozzles.
Elsewhere I have read
suggestions to just do one nozzle at a time. However, I found out that
if you remove both red nozzles, you can then blow through one side and
it will come out the other. In my case, that dislodged a nice
collection of crystal-like chunks (guessing it may be crystallized
residue from the cleaning solution).
There was also a bit of
blockage in one of the red nozzles, which I cleaned out. Make sure you
can blow through both of them with little resistance.
Reassemble:
Push red nozzles back into hoses. Using pliers, reposition sprung clip
back over the red nozzle. Snap nozzles back into place. Refill tanks
and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
SOURCE: water will not spray on my Bissell Proheat 2x Carpet cleaner
proheat 9300
assuming the water will flow with the tool attachement but not to the carpet.
Remove the water tank. You will see 2 red tabbed plastic spray tubes.(where the spray comes out if not clogged) Pinch the clips to remove from the machine. Then you will need to pinch the hose clips to remove the red tabs from the hose. Clean out those red spray nozzles. Next step: have a towel ready and fill the solution tank with water. Put the solution (not water) tank on to where the water tank would go. Place the machine selection knob to rinse/wet only. Now with towel under the hoses that you removed the red tabs. Turn on the machine and pull the trigger to activate the water. You should see water flow out of the hoses that had the red tabs on them. If not, release and pull again the trigger several times. If only 1 hose has water coming out of it then block the one that works and try the process above again to de clog the one that isn't working. Good luck.
