From the
owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out
bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available
from your
GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently
turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling
straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille
that hold it in place and sliding the grille to the left (opening the
door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
