SOURCE: SIEMENS GIGASET A160 TWIN CORDLESS PHONE
It's not an easy website to navigate, but if you look hard the all the information is available.
Is this the page you were looking for Graham?
Regards,
Spare head 2.
SOURCE: Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to www.cordlessrepair.com
SOURCE: i need to download drivers for Siemens Gigaset SE505 dsl/cable
Routers don't have drivers. If you are looking for firmware updates instead, here is a link:
http://gigaset.com/shc/0,1935,hq_en_0_23016_rArNrNrNrN_prodId%3A15702,00.html
If you are lookin for setup instructions, here is a link:
http://gigaset.com/shc/0,1935,hq_en_0_23014_rArNrNrNrN_prodId%3A15702,00.html
SOURCE: Reseting the admin password on siemen gigaset modem
Usually at the back of the modem has an inside button (it has the tag "reset") that u can push it with the help of a object that has a point. (e.g pencil).
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
