SOURCE: Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
SOURCE: My Jura S9's grinding unit clogged (due to Peete's beans)
Use the TABLET CLEANING. please refer to this manual here on page 24 if you don't have one.
Regards
SOURCE: My Jura Ena 5 gives a 'fill beans' message
Same thing happening to me right now. I think this has something to do with having used flavored beans (which I was warned not to do). Supposedly they gum up the machine.
Please dont forget to vote if you liked my answer
thanks
