JVC Everio GZ-MG21 Camcorder Logo
Posted on Apr 04, 2009
How to transfer videos from camcorder to pc
Unable to transfer from hard disk to the pc
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Apr 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
3532
Points
8
Probably Mod video converter can solve your problem. It can export .mod files to MPG, AVI, WMV, MP4, MOV, 3GP, RM, FLV, SWF, etc.
2 Related Answers
Anonymous
  • 117 Answers
  • Posted on Jun 16, 2009
SOURCE: Transferred videos from Sony Handycam Camcorder dont have sound
iorgsoft mod converter will solve the problem http://www.iorgsoft.com/Mod-Converter/
Anonymous
  • 87 Answers
  • Posted on Dec 16, 2009
SOURCE: Transfering vid/pics from SONY DCR TRV285E camcorder to a PC
You have use only the sony software to transfer the picture and the videos. The software have a default location. Go to that location and you will find all of them
How do you transfer video on the hard drive to the memory stick?
Unable to transfer a video recording made on the hard disk drive to the Memory Stick Duo™ media Solution
sp.gif sp.gif Do the following before attempting to copy movies to the Memory Stick Duo media:
  1. Ensure an Image Database File has been created on the inserted Memory Stick Duo media.
  2. Ensure there is enough space available on the Memory Stick Duo media.
NOTE: For model-specific information about how to transfer a video recording, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
How can i copy the recorded to my pc harddrive
Just get the USB cable (make sure the end that goes in the Camcorder is the right one) hook it to your PC then when you hook it to your PC you can find software to transfer or since it will make you Camcorder like a Hard Disk drive (if you are fairly computer savy) just transfer directly! Hope it helps
Unable to Load software
Did you try uploading using a firewire card and firewire cable? It is an alternative to USB and is the most preferred way of transferring video from the camcorder these days. Also did you try uploading the video using windows movie maker? COnnect your camcorder to your computer and press the capture from camera option to capture the video on your camcorder to your computer. If you have already tried everything then the simplest way to transfer is to remove the 1.5" hard drive connect it to your computer(your computer should have SATA connector), transfer the video and put the hard drive back into the camcorder. Might sound crazy but its a very effective way considering the fact that it is quite easy to remove the hard disk from most camcorders.
Let me know if you need more help,
Sai.
Trouble transferring video's from JCV camcorder to PC.
i need a beginner manual to learn the camara hoy do i get one
1helpful
When I transfer videos from canon fs100 into my pc, it wouldn't transfer any sound. thank you
I also am facing the same problem. Even the videos can be played in PC, then don't give any sound at all. And I have no idea about it too. Really stuck at that point. Another thing is; how to disconnect the camcorder from PC although I remove the hard disk of it via safely remove, as it always warn "PC connected, WHILE THE CAMCORDER IS CONNECTED TO A PC DO NOT DISCONNECT THE USB CABLE OR POWER SOURCE, CANNOT TURN OFF POWER OR CHANGE MODES" in its display LCD. So, What I am gonna do???? Actually for transfering the images and videos from your camcorder to PC is; you need to install PIXELA ImageMixer 3 SE first, which is aldy in your kit. Then, you can edit and browse the videos and images from your camcorder.
P.S: If somebody knows how to solve these, please share the solutions. Thanks! Am I wrong to purchase that Canon FS200 because of its external audio jack(whereas others don't have that access), compact design and reasonable pricing ?
What do I need to transfer video from jvc cam to my laptop
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
You can then use Move Maker to any disc burning software like Nero to create the movie disks.
1helpful
2answers
TRANSFER VIDEO TO PC
the samsung website has a vista update driver for this problem
Software
remove the SD card from the camplug it into your PC. If it has no card slot, get a USB card reader. Less than $20 usually. Make sure the card reader can handle the SDHC (hi-capacity) cards if you plan to use those. If XP recognizes the card it will appear like an additional hard disk. Open it in windows explorer, check the directories until you find your video or photos and copy those to the hard disk.
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
