We have no full picture in the middle of viewing a tv show. Sometimes we get half screen sometimes we get a line across with no other picture. This happens daily with both tv use and dvd use.
Thanks so much. But when we use the DVD player and don't go thru the cable to watch a DVD, shouldn't it work? It cuts out on us then too which is why I thought it was the tv...hmmm.Thanks so much. But when we use the DVD player and don't go thru the cable to watch a DVD, shouldn't it work? It cuts out on us then too which is why I thought it was the tv...hmmm.
sorry, solution#2, just says " lines of screen" did your sentence get cut off?sorry, solution#2, just says " lines of screen" did your sentence get cut off?
You can't post conmments that contain an email address.
It may be a problem with a cheaper HDMI cable. If the cable is too long or if the cable is of a cheaper quality, you may be able to solve the problem with a larger and shorter "pipe"
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
