SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
SOURCE: Oven will not heat
Hello, your problem is going to be a bad igniter. you should replace it. Good luck! Mike
SOURCE: Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
SOURCE: My Maytag Gemini oven is
F9-2 error code indicates:
