HDDformat error E:31:00 tengo este problema q no puedo ver nada de nada ni tomar videos ni fotografias nuevas. modelo DCR-SR21
SOURCE: Notebook Sony Vaio VGN-FJ270
La única manera de hacer esto es hacer una recuperación de sistema en el disco, si se asume que esto fue fijada realmente y funcionamiento. ¿si no, usted tiene un respaldo para estos datos?
SOURCE: PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
[[Direct Accessories and Parts Center, DAPC]]
How to use a Sony® camcorder as a webcam using USB Streaming.
Solution
IMPORTANT:
NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
SOURCE: tengo un macintosh y no
Please get the best driver for your handycam here :
www.givemefile.net > ... > Digital camera > SONY
www.ps2netdrivers.net/driver/sony.dcr-trv480e/
esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV22
www.userdrivers.com > Camcorder > Sony
Jay
