SOURCE: fault code 010-110 for 3535
The fuser exit switch sees something in the fuser. The exit switch is stuck . there is actually a piece of paper in the fuser.
Or the switch fell out of the slot.
You can just losten the two thumb screws on the fuser , remove the fuser and check it out.
SOURCE: reset fault code 010-348
go to system settings
common setting
NVM read Write and
put the code 744-003
if it is showing value 1
then enter it to 0
press save and close
this is for 10-348 code resetter
Thanks I have replaced fuser and left machine a few days, still displays same fault code. Is there a way to clear the code using the control panel?
