Code for sky plus remote please
Please help me with code for sky plus remote
tv model thomson 27lb011s4u
rev 8 sky remote
thanks
Hi, the code is 1130, i have the same television and the code works perfectly with a rev 8 sky+ remote.
Posted on Mar 26, 2010
SOURCE:
I need a code for sky remote control for LG tv model no.M198WA
The correct code - or whether there is any code - depends which version of Sky remote you have. This can be found on a sticker inside the battery compartment. The Sky info for your TV is somewhat confusing. Sky have an exact match for your TV model number but if you have the RC1600/00 remote, Rev 4 or Rev remote, they do not list any codes. If you have the Rev 8 remote, they list the following codes: 0206 1293 1280
However, despite listing codes for the Rev 8 they also state that "these codes are not available for your version of the Sky remote" - confused? I am.
So, I suggest you try the above codes regardless of which Sky remote version you have and if they do not work, also try the generic codes for LG TVs for each version of the Sky remote:
Rev 4: 0065 0742 0502 0672 0634 0136
Rev 6: Same as Rev 4
Rev 8: 1293 1177 1206 0206 0065
Basically, I suggest you try all of the codes above regardless of which version of Sky remote you have, including RC1600/00. There's a good chance one of them will control the volume and standby functions.
If none of the above codes work, please post back, let me know which version of the Sky remote you have and I will try to assist you further.
Regards,
BElectric
Dec 17, 2010 | Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Sky remote code for lg television model no.32pg6000 to programe remote controll on sky remote
Code is 1293 if you're using a Rev 8 remote control. You can check this on the sticker in the battery compartment.
If you are using an older Sky remote Rev 6, Rev 4 or plain old RC1600/00 then it's unlikely to work as these remotes aren't programmed to control your TV. You are welcome to try though ;)
Please post back if you need instructions on programming the remote.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | LG L3200AK Television
What is the sky remote control for Samsung
Hi
Samsung
4 digits: 0060
3 digits: 065, 584, 037, 245, 476, 398, 516, 292, 318,037
Samsung (6000 series)
4 digits: 1340
As you used 0060 and it didnt respond please try to programma with the other 3 didgit codes.
If still you cannot programme it follow the below instruction:
1. To control your TV firstly switch on the TV set, point the Sky remote at the TV,
2. Press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice.
3. Continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will start using the inbuilt codes to programme the remote.
Thanx
Jul 27, 2010 | Samsung Televison & Video
Need the sky remote code for bush s626d lcd tv. cant find it anywhere!!!please help
The Sky engineer told me that there wasn't a code for this model TV but thanks to the guys at:
http://genuinecopies.tv/skyCodes.asp?brand=bush&model=s626d
I was able to find it the code is : 206
This was for a REV Ver 8 Sky remote.
Their code finder should work for other models too.
Feb 28, 2010 | Televison & Video
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Sky remote code for LG 42LC46 tv
Hi - I also have the LG42LC46, i got it to work by using code 206 but you need a REV 8 remote, i tried it with a REV 4 and it doesn't work.
Regs
Dee
P.s. let me know if it worked for you.
Mar 20, 2008 | Televison & Video
Code for Samsung remote control
With your Sky + remote.
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 29, 2007 | Samsung TV Remote Control
LG RZ17LZ40 remote control code
I have got the RZ17LZ40 tv from LG and just got my new Sky Plus remote Rev.8 to control the tv by using code 0206.
Sep 23, 2007 | Televison & Video
Sky+remote code for my lg tv
The cose you need is 0206
Sep 15, 2007 | Televison & Video
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
