The second button from the left on the bottom corner by the power button is the brightness button. If you press it the brightness menu is pop up on the screen. With the menu up you just use the three buttons on the left to select the function and the increase or decrease the brightness and contrast on the monitor.
BuddyMc
Thank You!!!!!
RTM, find it read it. google finds it in 1 second flat.
page23 covers this.
https://usermanual.wiki/Dell/DellCompute...
push 1
the push +/- as needed. 1st google hit,btw.
First google hit.
"Dell E178FP manual"
the manual.
SOURCE: brightness and contrast screen in center of monitor and can't remove it
the micro switches on the monitor are getting short which is triggering the menu, try to clean it with a switch cleaner or check if the switches can be replaced, do this only if u r an expert in handling things like this or take some proffessional assistance.
SOURCE: BRIGHTNESS/CONTRAST WINDOW FLASHING
The front panel switches are known to become leaky.You need to replace these switches.
Samir.
Please rate the solution and provide feedback
SOURCE: Unable to adjust contrast
http://support.dell.com/support/edocs/monitors/r83546/EN/setup.htm#Using the OSD
"NOTE: When using DVI source, the contrast adjustment is not available"
SOURCE: Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
SOURCE: dell 1900f monitor contrast/brightness problem
CLick start/run then type in dxdiag. Go to the display tab and click test dirext3d. There should be an 3d cube that comes up and spins around. After the cube leave cancel everything else and close dxdiag, Your problem should be solved for a pretty long time. If it happens again just follow the steps again.
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
